Autopilot
I have a lamp I want to add a smart switch to for Alexa control, routines etc. I normally use Kasa smart plug, but they are too big to use behind the shelves the lamp is on. I plan to cut the cable anyway, so might as well use a Zigbee (or similar) in-line switch.
Correct me if I’m wrong, I won’t need a Zigbee hub because the Amazon Echo Plus I have had one built in, but which is the best switch (preferably on Amazon)?
