Decent free media software?
Discussion in 'Music & Music Streaming Services' started by bobbymax, Feb 27, 2014.
  1. bobbymax
    bobbymax
    Feb 4, 2007
    1,993
    Hampshire UK
    +190
    Hope this is the correct forum to post this....
    I'm using Media Jukebox 14 at the moment, but getting a bit fed up with not being able to get the covers for albums I upload to it. Although, some of them have show the covers automatically.
    I right click on the album, but Can't see anywhere to find covers on the web or similar, and even the "Rename" button is greyed out.
    Now it's very possible (Likely. :D) that I'm not using it correctly.
    If so, can anyone point me in the right direction, or recommend another media player :lease:
  2. probedb
    probedb
    Aug 20, 2003
    2,660
    Sheffield
    +180
    What are your requirements? Is playback on a PC or a Mac or is it being streamed to an external player?
    Depending on your requirements there are quite a few, from foobar2000 to XBMC :)
  3. bobbymax
    bobbymax
    Feb 4, 2007
    1,993
    Hampshire UK
    +190
    Thanks for that.
    I Have a PC (win 7) and should have said, I just want a decent music storage (ripping CD's) and organizer similar to itunes etc.
    i have Media Jukebox 14 at the moment, but I can't get the covers/artwork to show on the albums. o_O.
    so thought I'd trie something else that will store music in it's full capacity (lossless) and can burn to disk etc. ;)
  4. probedb
    probedb
    Aug 20, 2003
    2,660
    Sheffield
    +180
    Personally I use dbPoweramp for ripping, it has AccurateRip support and access to lots of artwork/meta data. Storage is wherever you want to put it and you rip to whatever format you want to.
    I think you just need to try a few and see what you like. I use fb2k because it's easy to use for me and fairly flexible in how to set it up and there are lots of plugins for various things :) Something like XBMC would be better if you dedicated a box to it.
    As for covers, does Media Jukebox require the artwork to be in a particular place? Maybe folder.jpg or cover.jpg in the album folder, or does it support artwork embedded in files? I'm assuming you're using FLAC for lossless.
  5. Kailash
    Kailash
    May 5, 2006
    1,438
    +463
    I use iTunes but a lot of the time album covers don't come up, so I just grab a pic from the net and upload it. not that convenient but only takes a few mins
    I doubt any program will always give you the cover, as long as you get the majority of them though
  6. bobbymax
    bobbymax
    Feb 4, 2007
    1,993
    Hampshire UK
    +190
    Yes I do prefer to have FLAC or something similar (not very knowledgeable with music compression afraid). I want to write to Disk, so need the best quality ;)
    And to cruiser...thanks but I don't really like i tunes as it's predominantly MP3..isn't it? And like I said I 'd want the full quality from my music... but if itunes will give me that then I'd change my mine. :)
    Cheers guys.
