Decent Bluetooth Earbuds
Discussion in 'General Tech & Gadget Forums' started by nightofjoy, Feb 25, 2014.
  1. nightofjoy
    nightofjoy
    Jul 11, 2012
    59
    +7
    I'm looking for a pair of bluetooth earbuds, decent quality at a low price. They don't need top of the range features, or more than 2-3 power per charge. They'll probably be used for working out, so a strong bluetooth connection is probably the most important element. Be nice if they stayed in my ears too.
    I've been looking at some reviews, and a couple keep cropping up, but I wondered if I could find any hidden gems by asking on here...
    Cheers.
  2. everett_psycho
    everett_psycho
    Nov 20, 2009
    8,095
    Christchurch NZ
    +2,620
    Not necessarily buds but Sony make Bluetooth receivers with 3.5mm jacks and a small display. I've got an old model that was the mw600 and it's fantastic. The device is smaller than an mp3 player and clips on but it means you can use any buds you like with it, they do come with some half decent ones with a short cable but if you have problems it's easy to upgrade just the buds fairly cheaply
  3. cdrider
    cdrider
    Oct 1, 2003
    739
    +43
    Jaybird Bluebuds X. Pricy and can be a bit difficult to find the right bud fit for yr ears but the sound is excellent and they very rarely drop out.
  4. EddieThorogood
    EddieThorogood
    Mar 16, 2014
    4
    Bingham, Nottingham
    beats powerbeats 2 have just been released... check them out
