Decent ADSL modem Gaming Router???
Discussion in 'Xbox Forums' started by JNV, Dec 19, 2006.
  1. JNV
    JNV
    Dec 15, 2005
    254
    Soton
    +8
    Plz can some1 help, ive been searching the internet for a good Xbox live compatible wireless ADSL modem router. The Xbox website lists several cable routers, but no modem routers.
    Ive had a linskys router which blew up, and am now using a D-link DSL-G624T which keps loosing its signal, disconnecting me from live. I then have to sign out of my profile, and then sign back in. Or connect to xbox live again. This gets really annoying when you get a decent game going.
    Is anyone using a router for live which they can recommend, im really looking for a gaming router but any suggestions are welcome.
    Thanks in advance JNV
  2. dng007
    dng007
    Apr 26, 2005
    594
    28
    Harrow
    +47
    I'm using a Netgear DG834G ADSL router. It's got 4 ethernet ports (so you can connect up to 4 devices at once), and is wireless (54Mbps). I'm more than happy with it, and connect my XBOX 360 up to is using the MS wireless adapter. Never had any problems with it either.
  3. runam0k
    runam0k
    Dec 16, 2005
    3,458
    London
    +217
    A quick search (of this forum) and you'll 101 recommendations for the Netgear router above.
    I'd also recommend the Dynamode R-ADSL-C4W-EG
    and the ZyXEL P660HW (both good value for money, easy to set up, lots of advanced settings to tweak and very reliable). In my experience.
  4. mart1977
    mart1977
    Dec 10, 2005
    387
    28
    +29
    Also using the Netgear DG834G. Been online for 2 weeks now and had no problems at all. Also look on www.xboxlivetheguide.co.uk for exact instructions on setting up that model of router.
  5. JNV
    JNV
    Dec 15, 2005
    254
    Soton
    +8
    Thanks for your replys guys, i'm probably gonna try the Netgear one, however after searching on ebay i see that theres a V2 model now. Not sure whether to spend the extra and get the V2, or stick with the original one that everyone speaks so highly of??
  6. ShadowmanUK
    ShadowmanUK
    Feb 14, 2006
    1,299
    63
    +132
    V2 or V3 are the best ones
