Decent 32 inch Android TV with Google Playstore
Geebsie
As it says above - any recommendations? This is for a bedroom with no aerial socket - hence the ability to install a decent array of Google Playstore / third party apps is essential. Thanks!
Derkster
I bought this one for my daughter. Its bang on for the money
AVtest
You would benefit from mentioning country.
Dont want to disappoint you but take android tv with a little pinch of salt. Tv manufacturers stick mediocre hardware so dont expect miracles with android there. Also playstore is limited to compatibility with manufacturer. Dedicated tv box might be better option. But if you still want one tlc does one;
TCL 32ES568 32 Inch HD Ready Smart Android TV
Panasonic HZ2000 OLED TV Review: The best OLED for movie viewing in 2020
