December Entry
Discussion in 'Past Entries' started by Liquid101, Dec 19, 2006.
  1. Liquid101
    Liquid101
    Jan 30, 2006
    8,144
    Aberystwyth
    +3,234
    Finally got around to doing something about this months comp... I was going to try and come up with something different, but ran out time (Leaving for an extended Xmas break to Somerset in a few days). So popped out this evening and made this photograph of my workplace.
    For some reason I can't make the exif data stick... I've tried all sorts, just isn't happening. (Zone - I'll send you the RAW file if you want)
    But for the record, this is what it is:
    Nikon D50
    20mm
    ExposureTime : 25.00Sec
    FNumber : F16.0
    ExposureProgram : Aperture Priority
    DateTimeOriginal : 2006:12:19 17:01:35
    ISO: 200
    Converted from RAW - Small tonal/colour adjustments, removed slight flare, corrected perspective.
    [​IMG]
  2. vulkan75
    vulkan75
    wow.
    I really like it.The light stream from the passing car really makes this shot,was this intentional.
    really well done
    :smashin:
    what is the building by the way,you dont work for MI6 do you?:cool:
    I Hope this will be a valid entry,A contender for sure.
    :hiya:
  3. tontoshorse
    tontoshorse
    Sep 30, 2005
    3,359
    +693
    Excellent, I also like the car headlights, not just for the streaming but also for the extra lighting it provides on the foreground landscape.
    "popped out this evening" lol.:rotfl:
    Really! you just have to put a little more effort into this!:D
  4. Liquid101
    Liquid101
    Jan 30, 2006
    8,144
    Aberystwyth
    +3,234
    Thanks for the comments.
    The foreground was almost black without the headlights - thought about using flash, but the 20mm 1.8 is a monster, and gets in the way of the little on board speedlight. With staff constantly leaving at this sort of time, it was the natural way to do it ;)
    I'm sure i'll have to field lots of questions about what I was doing when I go into work tomorrow, at least 20 cars must have passed me in the few minutes I was there.
  5. Zone
    Zone
    Jun 24, 2001
    6,871
    Barnsley
    +2,674
    How are you saving it after converting to jpeg?
  6. Liquid101
    Liquid101
    Jan 30, 2006
    8,144
    Aberystwyth
    +3,234
    Just using 'Save As' which should work. I have also tried 'Save for Web'
    I have also tried converting to TIFF in Rawshooter, then opening in Photoshop, and re saving in both ways... just doesn't want to work.
    The only way I can get it to stick is by converting to TIFF in Rawshooter, and leaving it at its full resolution.
    It's probably because i'm using Photoshop 6 (I know) which might not support the header file.
  7. Zone
    Zone
    Jun 24, 2001
    6,871
    Barnsley
    +2,674
    Agree I also think ps6 is the problem, I'll pm you my addy to email the original to, though if you can make the file size as small as possible then its always a help :D
  8. Zone
    Zone
    Jun 24, 2001
    6,871
    Barnsley
    +2,674
    Liquid101's picture emailed to me and exif is fine:smashin:
