Debranding of a samsung d900
Discussion in 'Mobile Phones Forum' started by El Jas, May 7, 2007.
Tags:
  1. El Jas
    El Jas
    Mar 15, 2006
    16
    Has anyone done this and if so how and was it safe to do so, I have read a few threads where it has knackered peoples phones. Not sure if it was their fault or a risk you have to take. Or is there another way to change the text tones as this is my main reason as I think I'm right in saying it's the only option available to change my text tones as the t mobile ones arre crap.:confused:
  2. ram33
    ram33
    May 28, 2005
    1,150
    48
    +61
    dont know about the text tones, but it would be safest to get it debranded by a pro with the correct equipment as you will have some comeback if it go's wrong
