Death of Arcam DV88+
Discussion in 'Blu-ray & DVD Players & Recorders' started by Bernard Barnett, Sep 26, 2003.
Tags:
  1. Bernard Barnett
    Bernard Barnett
    May 16, 2002
    671
    Norfolk
    +5
    My three-month-old Arcam DV88+ appears to have died. I switched it on last night, or rather attempted to, and nothing happened, no lights, nothing. Disconnected from the mains and reconnected - still nothing. Checked the fuse in the plug and it's not that. Tried a different wall plug but it's not that either. I'm going to take it back to the shop this morning but wondered if anyone had had a similar experience. Also if anyone knows what my rights are in asking for a loan machine while it's being fixed (probably none).
  2. Craig Sowerby
    Craig Sowerby
    Nov 14, 2002
    313
    +27
    You cannot force the store to loan you a machine, but i would'nt
    think you will have to try, a good dealer will probably offer you one anyway, but if not just ask.
    I have never had a DV88 die like that.
    Good luck anyway.
  3. Matt Horne
    Matt Horne
    Nov 20, 2000
    4,132
    83
    Over the Hill & Far Away
    +119
    Sounds like the internal power supply has gone bang ?. I have never got a loan machine out of my dealer.. always some crap excuse. But Arcam are usually very quick in turning the repairs around.. or maybe try and twist the dealers arm for a new one ?
  4. Bernard Barnett
    Bernard Barnett
    May 16, 2002
    671
    Norfolk
    +5
    Thanks Craig/Matt. Yes, probably blown an internal fuse. Took it into the shop and they're sending it to Arcam. Couldn't predict how long it would take. And sure enough, crap excuse about no loaners.
