Dead Sony....... HELP !!!!!!
Discussion in 'TVs' started by Zog, Apr 25, 2003.
  1. Zog
    Zog
    Aug 16, 2001
    426
    Manchester
    +5
    My huge mutha of a CRT Sony appears to have bitten the big one.
    Despite a few "reset" attempts, I just can't get a picture.
    Strange thing is, the Stereo A/B indicator LEDs on the front of the set appear to be trying to talk to me. They are flashing in a repeated pattern.
    One of 2 patterns depending upon how I try to switch on the TV.
    Either; A once followed by B thirteen times
    or..... A once followed by B three times.
    Anybody any ideas ??
  2. mmm
    mmm
    Dec 6, 2002
    98
    Kent
    What type is the TV ?
  3. Zog
    Zog
    Aug 16, 2001
    426
    Manchester
    +5
    It's a KV-S 3432U.
  4. FCP FAN
    FCP FAN
    I now inform you that your tv is dead.
    My feelings, as usual, is that you´ll need to send it to be serviced.
  5. Zog
    Zog
    Aug 16, 2001
    426
    Manchester
    +5
    Gathered that numpty !!!!!
    But what does the future hold a brand spanking new 40" Plasma or a £200 repair bill ??
  6. Orbitalzone
    Orbitalzone
    Feb 23, 2002
    394
    E.Sussex
    +43
    13 flashes happens a lot on faulty Sony's... trouble is I can't quite recall which error it's reporting...
    I have a sneaking suspicion it can be due to failed line output drive (either the lineoutput transformer or the lineoutput transistor)... but a dry joint could equally cause this fault... and depending on the age, dry joints on Sony's aren't that unusual like most TVs (bar Panasonics perhaps)
    I think you really need a repair man to check out the TV to give an accurate diagnosis, but the less than technical way to establish whether it's a dry joint, is to... umm give the TV a little bash (gently) and see if it comes to life. If it does then dry joints are likely and not too expensive to have fixed...
    A failed Line o/p transformer however can be costly, maybe looking at £120 - £150 in total.
  7. HowieC
    HowieC
    Jun 9, 2002
    249
    London
    13 flashes indicates the voltage protection circuitry has activated.
    Can be caused by a range of probs, but many times by dry solder joints. 3 flashes varies from chassis to chassis, don't know it for yours.
  8. Zog
    Zog
    Aug 16, 2001
    426
    Manchester
    +5
    They're picking it up tomorrow.
    They can sort out the NTSC problem while they're at it. I've got a dozen R1 DVDs that I wanna watch.
