K
kev^
First of all sorry this is such a noobish question. I am sure my answer is lurking around these forums somewhere but I can't find a specific case the same as mine so I just want to be sure before I go off ordering anything....
At the moment I have my PC hooked up to a CRT monitor using a bog standard (d-sub?) connection.
I've just ordered a Dell 2005FPW 20" Widescreen monitor which has one DVI-D Input. My graphics card (a Geforce4 ti4200) has a DVI output. Using this picture - http://www.avforums.com/forums/showpost.php?p=1703389&postcount=4 it looks like it is a DVI-I Dual Link.
So simple question is what cable exactly should I be buying to hook these two up? I don't mind spending a *little* extra for a good quality one but I wouldn't wanna spend anymore than fifteen or twenty quid on this cable. It only needs to be a metre or two long.
