Dead Pixel?
Discussion in 'Projectors, Screens & Video Processors' started by Mr fuse, Mar 29, 2005.
  1. Mr fuse
    Mr fuse
    I have had my projector about 3 weeks and its devolped a dead pixel it wasnt their when I first had it is their anything I can do?
    Its an Epson tw-10H im guesing that with only one pixel I cant do anything about it, but its a little annoying because I know its their I keep looking for it. Im a newbie so any advice would be great.
  2. Tempest
    Tempest
    Jan 11, 2002
    5,821
    Horley, Surrey
    +1,256
    What colour is it?
    I had 2 red ones appear and (seeing as many films are generally on the dark side) a bright pixel really stands out.
    I took a yellow post-it note, coloured it black using a marker pen and cut out a pixel sized square and stuck in onto my screen over the stuck lit pixel.
    Now it's nowhere near as bad.
    Medium/dark scenes you'd never notice it at all.
    It's only in very bright scenes with no detail that you can see a small black dot, but it's way way better that a bright dot.
    Also as it's a post-it note sticky, it will come off the screen real easy without a mark.
  3. Mr fuse
    Mr fuse
    thanks for the advice its green so it does stand out in dark shots will try the post-it note idea
