Dead pixel or a stuck one?
Discussion in 'Plasma TVs Forum' started by lofty29, Oct 13, 2005.
  1. lofty29
    lofty29
    Sep 29, 2005
    202
    +3
    I have just noticed that one of my pixels is not right :eek: , how can you tell if it's stuck or dead, it seems to be spilt in half, with red one side and blue the other, it's at the bottom of the screen, so it's not a problem.
    Any info would be great
    cheers
    Lofty :thumbsup:
  2. 6022tivo
    6022tivo
    Aug 28, 2005
    637
    28
    +80
    I have the same, comes and goes, the green middle is missing, it is really hard to notice, near the edge and unless I am cleaning it and have a good look, I can't see it.
    Pio 505
  3. lofty29
    lofty29
    Sep 29, 2005
    202
    +3
    Yeah, that's it, not a problem though, but I have heard of the pixel fixer which apparantly fixes stuck pixels, but I can only find it in mpeg4 format which is meant for the sony psp, but it has a 60% success rate. I have it downloaded to my pc, so when I get it connected to my plasma, I will give it a whirl.
    It works by playing red,green, and blue solid squares VERY quickly, and it supposedly kicks the stuck pixel into life.
    Lofty :smashin:
