Dead or Alive 3 On a projector why won't it work ?
Discussion in 'Nintendo Forums' started by FoxyMulder, Apr 22, 2005.
  1. FoxyMulder
    FoxyMulder
    I am using a Panaonic AE700 projector and hooked up my X Box via RGB scart and enabled PAL 60 mode, unfortunately the display is half cut off when playing Dead or Alive 3 and distorted pic, Buffy works fine so its not the connection, anyone able to tell me how to make it all work as its my favourite X Box game.
  2. FoxyMulder
    FoxyMulder
    Anyone ?
  3. CAS FAN
    CAS FAN
    Nov 24, 2003
    35,343
    2
    167
    The Wheldon Road end!
    +8,369
    Maybe it's a PAL only game and you are trying to run it in Prog Scan? Men of Valor is like this and if I run it in Prog Scan I get a messed up picture but it's fine if I go into Enigma and change it back to PAL.
  4. FoxyMulder
    FoxyMulder
    I have progressive scan enabled on the projector i will deselect this and see if it makes a difference thanks for your advice.
  5. CAS FAN
    CAS FAN
    Nov 24, 2003
    35,343
    2
    167
    +8,369
    No probs :thumbsup: . In one respect I hope it works but then that would mean that DOAU doesn't work in Prog Scan, which would be a shame.
  6. FoxyMulder
    FoxyMulder
    Ok the only thing which works is to switch to the s video output and connect using s-video ( lower resolution and jaggies everywhere ) i'm using a cheaper RGB scart so i am thinking perhaps thats the problem and perhaps i should buy the official Microsoft Component or RGB scart kit ( don't wanna if i can help it as the cheap one does produce great images with no ghosting or side effects.
