Dead M/B ??
ferrytrip1
Hi - PC would not switch on yesterday - worked fine night before. Would not POST - no graphics at all.
Disconnected everything - just left memory, CPU & Video. M/B is MS-7125 with diagnostic LEDs. They are stalling at Floppy controller initialization. I have reset CMOS.
Do I have a dead board or is there anything else I can try?
Simon
ferrytrip1
Hi - PSU is only few weeks old.
I should have said - all seems to make right noises - fans all start I get the familiar single "beep" after switch on.
I think I have another psu in the attic - I will try it
Simon
Bagger
Simon
You turn on the system all fans spin up, after a couple of seconds it beeps.....Yes
This beep usually indicates it`s passed the Power On Self Test ( POST )
Check the monitor / cabling is ok
ferrytrip1
....Check the monitor / cabling is ok
I did not look here as the day before everything was OK and nothing had been disturbed. I disconnected the digital in and hooked up the analogue in - boots every time now.
So it must be a monitor problem with the digital input. Checked all cabeling - all seems sound - will investigate further - at least now I do not have expense of new board etc.
Thanks for the input - will advise if I find anything else
Simon
Synchro
Suspect its not booting up fully into windows and your monitor is not able to display the early boot up images. Is there a prompt whilst booting up via your analogue monitor?
