Dead Linn Karik 3
Discussion in 'Hi-Fi Stereo Systems & Separates' started by fontana, Aug 26, 2006.
  1. fontana
    fontana
    I have a Linn Karik 3 CD deck that has stopped working. When I switch it on, the power light comes on for a few seconds, then fades out (it pulses while it is doing this). If I switch it back on straight away, it fades ammost instantly, but if I leave it off for a while, it stays on for a few seconds again.
    I would be grateful for any ideas/advice on this, as Linn have stopped servicing the Karik. If it truly is dead and would cost too much to fix, I will replace it, but I wonder if it might be something simple like the power supply.
    Many thanks.
  2. Darran61
    Darran61
    Sep 2, 2006
    3
    Sheffield
    Probably the "Brilliant" power supply... I can put you in touch with a dealer who should be able to sort it...
  3. fontana
    fontana
    It was too much to hope that the mains plug might be loose, or something simple that would be free to fix! Life's not like that, I suppose.
    I would very much appreciate that dealer's details - many thanks. I will post the results.
