dead futronixs p100 light switch ????
Discussion in 'Home Cinema Buying & Building' started by grahamricho, Mar 29, 2002.
  1. grahamricho
    grahamricho
    Oct 29, 2001
    712
    York
    +13
    after a mcb tripped on my lighting circuit due to a bulb blowing, my p100 dosn,t work theres no led display nothing?i,ve tried reseting it but its still dead???????any ideas theres 240 v supply to it. thanks a diagram would be good?
  2. Alan Westy
    Alan Westy
    Aug 1, 2000
    Cheshire
    +13
    Graham,
    There is a internal fuse for each circuit inside the dimmer itself. I've had this blow when a light bulb has failed. Just get a new fuse from Maplin or somewhere and you'll probably be alright.
    Alan
