dead futronixs light switch 100 ohm resister?
Discussion in 'Home Cinema Buying & Building' started by grahamricho, Apr 2, 2002.
  1. grahamricho
    grahamricho
    Oct 29, 2001
    781
    York
    +20
    after taking the switch apart,a 100 ohm resister had a big hole in the side and read open,does any body no if its a fusable resister,and what wattage it looks quite big 1 or 2 watt. can you get circuit diagrams for the p100 ? futronixs haven,t repled to my e mail?
  2. Cliff
    Cliff
    Mar 17, 2001
    6,339
    167
    Kent Accra Rub Al Khali
    +3,764
    I would change the resistor. I think this is a "ballast" in series with the light circuits to absorb the surge when you switch on a cold filament lamp.
    Replace it - its not expensive and if it blows again - well you might be looking at the triacs.
    BTY I have P400 and so far I have just replaced fuses when a lamp goes- touch wood.
