Dead Denon - repair or replace
Discussion in 'AV Receivers & Amplifiers' started by petrieboy, Jan 31, 2009.
Tags:
  1. petrieboy
    petrieboy
    Aug 23, 2007
    22
    +3
    i have a Denon AVR 1803 which i bought second hand to go with my Jamo A102 speakers and home theatre pc. all was well and sounding fine until i shorted the speaker cables and now the thing switches off after a few seconds. ive unplugged everything, left it over night and done a soft reset but no luck.
    so - as i didnt buy this new, i dont know how old this is or what it was worth so do i pay for a repair (assuming its possible) and at what point should i consider it written off? (what should i be looking to pay for an equivilent quality amp?)
    also - can anyone recomend a repairer in the cambridge/herts/north london area??
  2. doug56hl
    doug56hl
    Feb 27, 2006
    5,724
    +3,661
    I don't know this unit but have you checked to see if you have just blown an internal fuse?
  3. petrieboy
    petrieboy
    Aug 23, 2007
    22
    +3
    two glass fuses on the power side both looked to be intact, other than that there was nothing obviously fuse-like under there. i was hoping for a big red "re-set circut" button but alas it was not to be :-(
  4. 100949football
    100949football
    Jul 30, 2005
    1,752
    48
    +39
    Hate to be a "predator -vulture" but if you are moving this on for spares please let me know as I am looking for a part for my Denon which has other problem.
    How old is yours?
    Hope you can fix it though!
    :smashin::smashin:: or as far as you are concerned :thumbsdow
  5. petrieboy
    petrieboy
    Aug 23, 2007
    22
    +3
    well i couldn't find anyone to quote for a repair so I've replaced with and Onkyo unit. what part is it you need - or do you need the whole beast? I'm sorry i don't know how old it is as it was 2nd hand - can dig out a serial number if that would help??
