De-interlacer and scaler question
Discussion in 'Projectors, Screens & Video Processors' started by Jonesthegas, Jun 11, 2002.
  1. Jonesthegas
    Jonesthegas
    Jun 5, 2002
    696
    Newcastle upon Tyne
    +26
    Are there any affordable single boxes which deinterlace and scale?
    If not, can you use a separate de-interlacer and scaler in the same setup (e.g. Tv-4000 and IScanPro)? If so, does it matter how they are connected?
  2. Gordon @ Convergent AV
    Jul 13, 2000
    14,214
    +3,058
  3. Jonesthegas
    Jonesthegas
    Jun 5, 2002
    696
    Newcastle upon Tyne
    +26
    About £600 - £700.
  4. Gordon @ Convergent AV
    Jul 13, 2000
    14,214
    +3,058
  5. Jonesthegas
    Jonesthegas
    Jun 5, 2002
    696
    Newcastle upon Tyne
    +26
    Thanks.
  6. md2
    md2
    I've just ordered a TV-4000 (otherwise known as ProV) because it is BOTH a deinterlacer and scaler....and it's relatively cheap.....and I've read good things about it.
  7. JSW
    JSW
    Feb 21, 2002
    4,284
    Staffs
    +333
  8. Jonesthegas
    Jonesthegas
    Jun 5, 2002
    696
    Newcastle upon Tyne
    +26
    If a de-interlacer lacks 2:2 pulldown, what is going to be like with PAL sources?
    Will a unit purchased in the US work in the UK (voltages and connections etc)?
    Can you wire a separate de-interlacer and scaler in series?
  9. Gordon @ Convergent AV
    Jul 13, 2000
    14,214
    +3,058
    Are there any cheap scalers that can accept a progressive signal without just passsing it through untouched.
    2:2 pulldown is only a requirement for playing back software which originated on film and is now in 50hz pal. This could be braodcast films on tv. or video or dvd.
    Gordon
  10. Jonesthegas
    Jonesthegas
    Jun 5, 2002
    696
    Newcastle upon Tyne
    +26
    So, If I buy a unit with no 2:2 pulldown, what would it do for PAL DVDs? Would it work at all?
    Martin
  11. Ludae
    Ludae
    Yes it would work and create a progressive output for PAL 50Hz but it would not produce optimal quality progressive frames from film sources recorded to video with a 2:2 field sequence such as 25Hz and 30Hz film sources.
    Having both 3:2 and 2:2 pulldown detection and compensation will potentially allow the de-interlacer to create perfectly de-interlaced video frames for all film sources on both PAL and NTSC video formats.
  12. Gordon @ Convergent AV
    Jul 13, 2000
    14,214
    +3,058
    Ludae: I think the thing that confuses everyone is that they think that DVD require 2:2 and 2:3 as that is what this feature is most discussed with.
    Everyone:
    Having 2:2 and 2:3 pulldown is of no benefit if the DVD in question was recored on a video camera (eg concert footage) or if you are watching the news at ten....these are most likely recored on video cameras and require a different de-interlacing algorithm to film based material or static images....
    Gordon
