De-gauzing?
Discussion in 'General TV Discussions Forum' started by Tommo24, Jun 5, 2003.
  1. Tommo24
    Tommo24
    I have a purity problem in the top left of my FS76.
    The engineers tried to fix it with the gun yesterday (5 times they tried). I am sure today that the picture is not as crisp and sometimes appears wavey. i.e. when putting up a channel box on sky the sides of the box are wavey?
    Does de-gauzing affect a sets picture and if it does will the problems fade? Ironically the purity problem is still there!!
    Tom
  2. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,425
    Somewhere in South Yorkshire
    +5,824
    De-gaussing (sic) should not affect picture geometry. The effect you describe (kinked/bent edges on what should be straight objects) is fairly typical of CRT TVs and results from inadequate components in the power supply. It can usually be substantially reduced by reducing contrast or brightness.
    The only way to avoid this 'feature' completely is to use Plasma or LCD, although some more expensive CRT TVs have this aspect under better control than others.
    And, if the de-gaussing has not cured the purity problem, more work needs to be done to the TV - unless it is caused by a nearby Louspeaker or something else with magnetism in it (perhaps a large steel radiator or similar, or an amplifier with a big transformer).
    Purity problems can be cured (by a well-trained engineer). It is done by attaching small permanent magnets to the tube inside the set.
  3. Tommo24
    Tommo24
    Good and helpful reply. Sounds like I could do with you trying to fix my sets problems.
    Thanks again.
  4. LV426
    LV426
    Jul 14, 2000
    13,425
    +5,824
    Much as I'd like to help - I don't have the skills, only a high-level knowledge of what, but not exactly how. You need a competent TV engineer.
