DD15 and F1200
Discussion in 'Subwoofers' started by dadalr, Nov 5, 2004.
  1. dadalr
    dadalr
    I would like to find out how I can connect Velodyne DD15 and Velodyne F1200 either to my receiver or daisy chain them. Any advice??
  2. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    You can connect any sub to a DD sub, it will even EQ it.
  3. Stellavision
    Stellavision
    Apr 7, 2003
    2,410
    Southsea, UK
    +105
    Why do you need to connect another sub to a DD15? :eek:
  4. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    Better in room frequency response before EQ.
  5. dadalr
    dadalr
    Because I already have F1200 and I need to add one more sub - room is too large for just one sub.
  6. dadalr
    dadalr
    how should i connect it the best way??
  7. Stellavision
    Stellavision
    Apr 7, 2003
    2,410
    Southsea, UK
    +105
    You can share the same input into each sub by daisy chaining them via the the THRU rca sockets on the back of the DD15.
    That must be a very large room you have there. How large is it?
