DD showing as pro logic 2 on amp
Discussion in 'Satellite TV, Sky TV & FreeSat' started by d.boyd1uk, Jul 26, 2004.
  1. d.boyd1uk
    d.boyd1uk
    Feb 27, 2002
    75
    I have just had sky+, bear with me.
    I have been to Audio and selected DD, I went to sky movies 1, harry potter was on, pressed "i", DD on banner, when playing back it was in pro logic, couldn't change it to DD, using HTR 5540 Yamaha amp, sky+ V1.
  2. Parklife
    Parklife
    Jun 9, 2004
    566
    28
    +33
    How are you connecting to your amp? You need to use a digital optical cable to get DD 5.1.
    You will also need to make sure your amp is set to receive it and not set to Pro Logic.
    If you have done both the above check another film as I did discover one the other day that was advertised in DD but I only got Pro Logic!!
  3. d.boyd1uk
    d.boyd1uk
    Feb 27, 2002
    75
    I am not using an optical, that must be the reason, any cheapies for sale?
    A guy in work told me about an xbox/ps2 optical would work fine, is this true?
  4. matty2767
    matty2767
    an optical lead with the correct ends will work fine. or if your equipment supports it - a digital coaxial lead is better.
  5. Nobber22
    Nobber22
    Jun 6, 2002
    2,979
    Berkshire
    +110
    Pace Sky+ boxes only have optical out.
