DD Room EQ-Is it acurate?
Discussion in 'Subwoofers' started by danny daniell, Jan 11, 2005.
  1. danny daniell
    danny daniell
    Jul 25, 2004
    1,400
    +62
    Have been having a few problems obtaining the correct settings on my 850.(nearly blew my left eardrum on friday when i had it set too loud :D ).I think i may have some serious acoustic anomalies in my room & as i am not technically minded,i thought that maybe the DD range with foolproof auto set-up could be more suitable for me.So,experieced users:did it work for you?
    Thanks,
    Dan :)
  2. recruit
    recruit
    Dan have you not got a BFD? as it will work wonders mate.
  3. MarkE19
    MarkE19
    Aug 10, 2002
    17,131
    Rainham Essex
    +2,393
    Dan, the EQ on the DD subs does not (at the moment!) offer auto setup. It is a manual process of trial & error to get a flat(ish) line across the frequencies and can take a long time to get right. But once you have worked out (or asked on here) how its done it is fairly straight forward and once completed gave me great room shaking results :devil: .
    I think 'auto EQ' is due sometime later this year.
    Mark.
  4. danny daniell
    danny daniell
    Jul 25, 2004
    1,400
    +62
    Thanks Mark,
    so "Dan proof" comes later this year? :laugh: Will it come as a software download to the current models(is that possible?) or will there be a new range?
    John,no i dont have a BFD but i think i bloody well need one (my left eardrum says so anyway).I have no problem with buying one,it`s just using it that puts the heebie jeebies up me :rolleyes: . Any sub-tweaker/BFD gods living close to the Kings Lynn area?There`s a drink in it for ya! :D
    Dan
  5. recruit
    recruit
    Where is Kings Lynn is it anywhere near Kent?
  6. Bruce Hall
    Bruce Hall
    Hi Dan,
    Version 2.0 of the DD software will be going into beta test this month, and be available for free download by March. All existing DD units can take advantage of the new software.
    It will have two types of EQ - an auto mode where you can watch the EQ adjust for room nodes on the graph screen, and a self-EQ where the unit EQs itself in about 90 seconds without even hooking up the video or EQ cables.
    There will also be other features like a full set of adjustable EQs per preset, selectable default preset, navigation and setup improvements, and other features.
    Hope this helps,
    Bruce
  7. Smurfin
    Smurfin
    Aug 13, 2002
    20,644
    +4,004
    Dan, remember the ASW875 comes out soon, though I'm not sure how advanced it is compared to Velodyne's EQ, and I'm not sure if it's auto...
  8. danny daniell
    danny daniell
    Jul 25, 2004
    1,400
    +62
    Wow! :eek:
    Thanks guys! Bruce,my room measures roughly 40ft*20ft*9ft high.Which Velo would do the job most effectively?
    Cheers Dan :)
  9. recruit
    recruit
    I would of thought a DD18 with a room that size..
  10. MarkE19
    MarkE19
    Aug 10, 2002
    17,131
    Rainham Essex
    +2,393
    or 2 :devil:
  11. danny daniell
    danny daniell
    Jul 25, 2004
    1,400
    +62
    It`s beautifull John,
    situated on the Norfolk coast,you should come visit sometime! :D ;)
    Dan :)
  12. recruit
    recruit
    Norfolk thats miles from me :eek: bet is nice too.
    Dan i would get a Velodyne!
  13. Curt Chisholm
    Curt Chisholm
    "Thanks guys! Bruce,my room measures roughly 40ft*20ft*9ft high.Which Velo would do the job most effectively?"
    Hi Dan,
    You need at least a DD-18.
    Curt (Velodyne Acoustics)
  14. danny daniell
    danny daniell
    Jul 25, 2004
    1,400
    +62
    Thanks Curt,
    Dan :)
  15. DanielB
    DanielB
    May 27, 2004
    158
    Switzerland
    +12
    Hi Bruce
    does Velodyne have enough beta-tester? :D
    Daniel
  16. stevebez
    stevebez
    Jul 11, 2004
    492
    +13
    How does it manage Auto room EQ without having the EQ cables connected?
    Rgds Steve.
  17. Bruce Hall
    Bruce Hall
    Hi Steve,
    There are actually two auto-EQ modes. The first is called "Self-EQ" and it works by simply hooking up the microphone, placing it in the listening position, and pressing 3-2-1 on the remote. The sub itself emits a sweep tone (not via the EQ cables) that the ic hears and uses to set the EQs. Then the unit saves and restarts.
    The second is Auto-EQ and can be found on the graph page. It assumes the EQ cables are connected and automatically sets the sliders when selected. After the auto-EQ does its thing, manual EQ can follow.
    Hope this helps,
    Bruce
  18. Pulsar
    Pulsar
    Jan 19, 2003
    2,925
    West Midlands - Stourbridge
    +292
    Bruce.
    Not wanting to put pressure on you, bt when can we expect to see the V.2 software?
    Rob
