DD on echostar reciever
Discussion in 'Satellite TV, Sky TV & FreeSat' started by mediamogul, Nov 3, 2004.
  1. mediamogul
    mediamogul
    Jan 25, 2002
    490
    Chatham,Kent
    +18
    Has anyone any ideas why i can not recieve Dolby Digital signals via my echostar 3600 reciever.Its connected to a Pioneer AX3 amp with a good Quality cable,but there is no sound or signal being recieved.My sky+ works well as does my dvd player.The Dolby is set to ON in the reciever and assigned to digital input on the AX3.Any thoughts appreciated,thanks
  2. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +979
    It would depend upon what channel you are tuning into via the Echostar, only three SKY movie channels and occasionaly the Disney channel broadcast using DD audio and they require a SKY digibox to receive.
    You would need to find a channel that the Echostar can access which uses the format, I think a few German and Austrian FTA channels do.
  3. JH4
    JH4
    May 6, 2003
    2,317
    63
    +227
    ORF1 on Astra 1 at 19deg East is in Dolby Digital. You should hear it OK if the setup is correct, ie. using the digital input to the Amp.
  4. mediamogul
    mediamogul
    Jan 25, 2002
    490
    Chatham,Kent
    +18
    I am using channels that broadcast in DD.the problem is im not recieving the DD signal from my av reciever.
  5. Nitemare
    Nitemare
    Jan 26, 2003
    34
    11
    Belfast
    @Mediamogal
    Are you using any CAM's with the receiver?
    If so these can disable the DD output...
    Try Pro7 on Astra 1H 12480V and see if you get a DD signal.
    Nitemare :smashin:
