dd dts out
Discussion in 'Blu-ray & DVD Players & Recorders' started by damien, Jan 12, 2003.
  1. damien
    damien
    can anybody tell me how to cancel the onboard dd dts decoders on a sony dvp ns 700 so i will just be using my sherwood rd 6103 amp for my dd dts thanks ps im using a co axle between the dvd ------amp
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,353
    Rainham Essex
    +2,441
    If your receiver is set to receive the sound via the coax input then you will be useing the amps decoder.
    To use the DVD's onboard decoder you need to connect the 5.1 analogue outputs on the DVD to the 5.1 analogue inputs on the receiver.
    If both are connected then you need to tell the receiver which input (analogue or digital) to use. If only the digital coax is connected then if you have sound you must be useing the receivers decoder.
    Mark.
  3. damien
    damien
    thanx m8
