DCRTRV250 ( Digital 8 )
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by solite, May 20, 2003.
  1. solite
    solite
    If i buy a DCRTRV250 can i transfer my old 8mm tapes to my pc to burn to disk:confused:
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,312
    Rainham Essex
    +2,425
    Most (if not all) Digital8 camcorders can play back 8mm/Hi8 tapes. Take one of your 8mm tapes to Jessops etc and try before you buy.
    As long as your PC has a firewire port and the correct software for capture/editing etc you should have no problems.
    :lesson: Find the best online price for the camcorder, take the detaiols of the retailer to Jessops and they will price match.
    Mark.
