DCD F100 Problem
Discussion in 'AV Receivers & Amplifiers' started by arranh, Sep 19, 2005.
  1. arranh
    arranh
    My CD player has recently stopped recognising that their is a disk in any of the CD trays. I have tried various discs in all three trays but it still says that there is no CD loaded. Anyone help?
    THanks
  2. Cable Monkey
    Cable Monkey
    Feb 10, 2002
    3,494
    Birmingham
    +205
    Sorry, there is little you can do other than decide if repair or replacement is the best option.
  3. arranh
    arranh
    Thanks. Can you recommend any repair outlets?
  4. Cable Monkey
    Cable Monkey
    Feb 10, 2002
    3,494
    Birmingham
    +205
    Any authorised Denon dealer should be able to arrange something or you can contact Denon direct and ask them to point you in the right direction.
