dcd-635 cd player info req
Discussion in 'AV Receivers & Amplifiers' started by fender62, Jun 5, 2005.
  1. fender62
    fender62
    Jan 11, 2005
    144
    19
    cowbridge
    anyone know anything about the denon dcd-635 cd player how old
    will it play cdr's. are they any good compared to newer cd players.
    pros and cons
  2. spiralp
    spiralp
    Feb 4, 2005
    I've got one of these. I bought it new around 10 years ago to replace a Pioneer bought in 1985. It was not top of the range, but was all I could afford. Build quality is good. Sound quality is OK (ish); plays CDR when it feels like it. Possibly my laser needs a clean. Quality wise it plays CDs better than a Denon 1710 DVD player, but that is not saying much. Any modern CD player should be better than the 635. I saw one sold on ebay recently for £5 - gives you some idea of its value.
  3. fender62
    fender62
    Jan 11, 2005
    144
    19
    cowbridge
    whats a good used denon to go for, i have a denon amp so id like to keep
    with denon gear. a denon cd that will play cdr's as well as normal ones
