dcd-485 cd player wont play bought cd's ?
Discussion in 'AV Receivers & Amplifiers' started by fender62, Aug 12, 2005.
  1. fender62
    fender62
    Jan 11, 2005
    144
    19
    cowbridge
    i bought aused denon dcd-485 cd player it wont play normal bought cd's only copies wha tcould it be is there anything i can try to remedy it, i tried a cleaning lens it didnt make any difference still will only play copies of cd's
    and not the original ones any ideas anyone what i could try please.
  2. briancbb
    briancbb
    About 6 weeks ago I purchased a DCM280 CD player, along with a 2805 A/V amp, both brand new. The DCM280 recognised some bought cd's but not all. If it did not recognise a cd, no matter how many times I tried it was the same result.
    The player was bought from Peter Tyson in the UK. A quick email exchange with them and although they had never heard of this problem before they swopped it out. Real good service.
    The swop out unit works beautifully.
    Sorry doesn't help out with your problem, but lets you know it has occured before.
    Brian
  3. fender62
    fender62
    Jan 11, 2005
    144
    19
    cowbridge
    thansk for reply i was wondering what the problem could be alignement tracking laser diod etc,
  4. fender62
    fender62
    Jan 11, 2005
    144
    19
    cowbridge
    thanks for reply i was wondering what the problem could be alignement tracking laser diod etc,
