DC10 and XP and Premier
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by Cliff, Jun 10, 2002.
  1. Cliff
    Cliff
    Mar 17, 2001
    6,338
    167
    Kent Accra Rub Al Khali
    +3,764
    Using Windows 98 I could capture staight to Premier using the DC10+card. Now, with my new XP 2Ghz machine I can't.
    Studio 7 with all the new XP drivers downloaded, works ok with the capture card so thats OK as far as Pinnacle are concerned.
    I used to be able to use AMCAP (part of windows) to see the DC10+ capture menu. Now nothing!
    I used to capture using the DC10 into premier then avisynth then TMPGE. Now it means using Studio to convert to an AVI file and import - which is not satisfactory.
    Any ideas out there how to get my capture card working with Premier again?
  2. JefUK
    JefUK
    Mar 31, 2002
    448
    28
    +54
  3. Cliff
    Cliff
    Mar 17, 2001
    6,338
    167
    +3,764
    Thanks for the link. As usual 5000 other people are trying to do the same as me and have failed from what I can see. Yes you're right - Premier uses Video for Windows- Studio uses Direct Show.
    Real pain as I use Premier( I use the alpha channel). So does this mean I have to capture in studio and export to premier using a(HUGE) AVI file (which compression?) or a DV file? then edit in Premier.
    I frame serve using Avisyth to TMPG
    Any comments - (Is there a clever way!)
  4. JefUK
    JefUK
    Mar 31, 2002
    448
    28
    +54
    Cliff
    I don't think there is a "clever way". If you capture with Studio 7 will the file not be accepted by Premier? I cannot test as although I have Premier I don't use it.
  5. Cliff
    Cliff
    Mar 17, 2001
    6,338
    167
    +3,764
    The DC10+capture card uses hardware compression to the MJPEG format.
    Premier does not recognise these files. If there was a plug in for premier so that it did we might be cooking gas!
  6. JefUK
    JefUK
    Mar 31, 2002
    448
    28
    +54
    The Pinnacle MJPEG codec can't be used with other applications. Try converting to DV-AVI.
  7. Cliff
    Cliff
    Mar 17, 2001
    6,338
    167
    +3,764
    I had a recent bit of success in solving this issue. From the Pinnacle forums I was able to download a Morgan Multimedia codec. This can be imported into Premier. You then capture the file using Studio - full stop. Open Premier and find the captured MJPEG file. Takes a lot of work to get the interlacing right. I had to invert the Morgan field sequence. Then experiment with the uppers and lowers in Premier and top and bottom in TPMGe. I have a few more grey hairs but at least I have eliminated a conversion!
