dbpoweramp flac ripping help
a2themfk
Established Member
currently trying to get all my cd's ripped to flac to use as master files, but im havin trouble converting them into mp3 lame as when selecting the album it wont me select the complete album as one instaed it only lets me select 1 track/file @ a time.
there's prob an easy way to select all but when i highlight the whole album to convert it only selects the last file :mad:
any pointers
cheers D
EDIT - Also could do with a few pointers how to use MP3tag ?
probedb
If no-one can help here give hydrogen-audio.org a go as at least one of the dbPowerAmp developers hangs out there.
DodgeTheViper
Tick the album folder box and all the tracks should have ticks next to them. If they dont, tick the album folder again.
It just selects and deselects the tracks.
twoodley
Established Member
Have you got the Batch Converter?
a2themfk
Established Member
cheers for the info guys, im using using it as ive said, it imports an album as single tracks into my music and im sorting them into ablums once there inported. there may be an easier way but this works if not a bit long winded
peter312
Established Member
You can use the naming option to specify individual album folders. For example (on my laptop, which uses XP):
Path: My Documents\My Music
Naming: [album artist]\([year]) [album]\[track] [artist] - [title]
For example, this gives me:
a file called "01 Electric Light Orchestra - Turn to Stone",
in a folder called "(1977) Out of the Blue",
in a folder called "Electric Light Orchestra",
in the "My Music" folder.
As mentioned above, using the dBpoweramp batch converter allows you to convert a whole album at a time (or many albums if you wish).
Hope that helps
a2themfk
Established Member
Hope that helps
cheers bud that works a treat !
now my nxt problem, converting the flac tracks to mp3 using dbpoweramp music converter, there seems to be no way to change the dymanic settings to change the path for artist tiltle etc like the above to create an artist, album, track, folders rather than seperate tracks
peter312
Established Member
using the batch converter, once you have selected the files you wish to convert, hit the convert button and a new box will appear (after a slight pause) and it will give you the same options.
HMHB
Outstanding Member
What version of dbpoweramp are you all using? Do I need the reference version if I want to rip to FLAC and MP3 at the same time ? Also I'd like the command line option.
a2themfk
Established Member
downloaded the mulit encoder but again there's no option to change the dymanic options to change the path, it set to default and i wont let me select that option :mad:
still no luck, even with both flac and mp3 codec paths set to doifferant folders and in the multi codec path set to orignal folder both files end up in the same folder !
Sony A84L/A80L BRAVIA XR OLED TV Review - COMPARED to LG C3, Samsung QD-OLED & LG G3
Back
