Day One Controller Faulty?
Discussion in 'Xbox One Accessories' started by leebroath, Feb 6, 2014.
  1. leebroath
    leebroath
    Aug 7, 2005
    6,083
    4
    3
    137
    Scotland
    +1,327
    Guys have any of you got a Day One faulty controller?
    My controller on the odd occasion switches off and the light flashes, it's not the battery as I had just replaced it with a fresh one.
    I'm in 2 minds whether to send it off or not as it's the day one edition :(
    Has anyone sent thiers off and received a Day One Edition back?
  2. indie24
    indie24
    Oct 3, 2004
    994
    london
    +262
    I just called MS Chat and got a coffin coming for my Day one console. It has been fine since launch and the last 2-3 days both controllers will lose sync and games keep telling me to reconnect them. I tried factory resets, and holding power down etc but nothing worked. My lights would flash for a quick second on both controllers and reconnect; sometimes they would just keep flashing. I hope yours does not do the same but seems strangely similar to mine. I know its not the controller as I have tried both. Anyway did the Advance Exchange so new one will be here soon hopefully. What you could try is to play with the usb lead attached and see if it's ok but if your still having issues then call support.
  3. leebroath
    leebroath
    Aug 7, 2005
    6,083
    4
    3
    137
    Scotland
    +1,327
    Yes my controller light flashed now and again and that's when sometimes the screen would say 'please re connect'
    Are you getting a whole new console replaced? or just the controllers etc
    sorry just noticed, will they send you a day one back?
  4. indie24
    indie24
    Oct 3, 2004
    994
    london
    +262
    try the old holding the power button down for 10 secs and disconnect power trick. If that dont help, try re-syncing controllers. finally try to play with usb lead in and if it works, your day one console like mine might need to be repaired :(
  5. leebroath
    leebroath
    Aug 7, 2005
    6,083
    4
    3
    137
    Scotland
    +1,327
    The console is fine though mate ;)
  6. indie24
    indie24
    Oct 3, 2004
    994
    london
    +262
    The console may not be able to hold a sync with the controller, if thats the case then its fauly but I suggest you troubleshoot like I have said earlier :)
  7. leebroath
    leebroath
    Aug 7, 2005
    6,083
    4
    3
    137
    Scotland
    +1,327
    ill try my second controller then and see if that holds up
    i would rather just have to send my controller away rather than the whole console lol
  8. mattr
    mattr
    Mar 9, 2002
    339
    Near Camberley
    +19
    Mine occasionally disconnects mid game, even with fresh batteries.
    The casing is loose on it though, the left hand side creaks away when you grip it.
  9. indie24
    indie24
    Oct 3, 2004
    994
    london
    +262
    Yea, I was the same, I waited 4 days but after a full factory reset I knew it wasn't both controllers. But at least I can play with the usb lead plugged in until the new one arrives!
  10. indie24
    indie24
    Oct 3, 2004
    994
    london
    +262
    getting my new box delivered tomorrow, man that's fast. Only talked to them on chat today around midday.
  11. leebroath
    leebroath
    Aug 7, 2005
    6,083
    4
    3
    137
    Scotland
    +1,327
    Did u send them your xbox one already?
  12. indie24
    indie24
    Oct 3, 2004
    994
    london
    +262
    no did the advance exchange. They hold a £390 charge on my card and send me one first. I then send old one back in same box. They need to have faulty box back within 14 days or they charge me £390
  13. leebroath
    leebroath
    Aug 7, 2005
    6,083
    4
    3
    137
    Scotland
    +1,327
    That's good isn't it :)
    Is the advance exchange free?
  14. indie24
    indie24
    Oct 3, 2004
    994
    london
    +262
    they hold 390.00 against your card (no actual money is taken) but you must return faulty unit in 14 days.
  15. leebroath
    leebroath
    Aug 7, 2005
    6,083
    4
    3
    137
    Scotland
    +1,327
    I see on the Xbox support you can choose either a normal controller or the Day One edition
    So if I choose the Day One controller will they send the exact same back?
    Has anyone sent theirs back and got a Day One sent to them ad a workable replacement ?
  16. indie24
    indie24
    Oct 3, 2004
    994
    london
    +262
    got my new console, played an hour and no more disconnects so far! I'm sure if you send day one controller you'll get same back
  17. leebroath
    leebroath
    Aug 7, 2005
    6,083
    4
    3
    137
    Scotland
    +1,327
    They have set up a repair so now I send them the old one then they will send me a new one :)
    Is it a free-post? and would I be better purchasing signed for delivery?
  18. The SMF
    The SMF
    Nov 7, 2009
    1,792
    +154
    has anyones controller started to develop dead space on the analogue sticks??
  19. x3j3UKN
    x3j3UKN
    Dec 19, 2007
    2,654
    +647
    Do any of your controllers feel as though they are coming apart? Mine seems to pinch the skin by myleft palm
  20. The SMF
    The SMF
    Nov 7, 2009
    1,792
    +154
    the under palm sections just snap on and off i believe, my day one controllers (yes i have 2) left analogue sticks are starting to wiggle slightly without doing anything, exactly like the 360 controllers did, MS were supposed to have eliminated this :(
  21. jjgreenwood
    jjgreenwood
    Nov 20, 2009
    3,794
    137
    The depths of hell
    +1,033
    My day 1 edition controller creaks as the plastic doesn't sit right on the right hand side of the pad. I got a normal additional pad within a week and its perfect, couldn't be bothered to send back the other one so I'll use it for the rare occasion of local multiplayer.
  22. leebroath
    leebroath
    Aug 7, 2005
    6,083
    4
    3
    137
    Scotland
    +1,327
    Well I've just learnt that by sending the controller back recorded delivery to the Czech Republic will cost loads... ((Fuming))
    So I'm just going to keep it and use it as a spare if needed. Can't BELIEVE they don't offer free postage back to the repair centre.
  23. The SMF
    The SMF
    Nov 7, 2009
    1,792
    +154
    have you not tried unclipping the panel and refitting it then?
  24. The SMF
    The SMF
    Nov 7, 2009
    1,792
    +154
    yh sod that
  25. k17chy
    k17chy
    May 19, 2012
    6,054
    Billy Elliot country
    +3,500
    I've noticed with my controller's is if you twist them slightly they disconnect. Don't use my day one controller any more as it feels like it's going to fall to bits.
  26. The SMF
    The SMF
    Nov 7, 2009
    1,792
    +154
    umm if your twisting it its going to disconnect, your warping the pcb, boards dont like being flexed
  27. k17chy
    k17chy
    May 19, 2012
    6,054
    +3,500
    It's only very slightly. I can do it with my 360 pad to the point of destruction and it's fine.
  28. The SMF
    The SMF
    Nov 7, 2009
    1,792
    +154
    dont understand why you would even do it slightly, was the controller designed to be flexed or twisted, no
  29. Nukleuz
    Nukleuz
    Aug 23, 2006
    647
    Manchester
    +360
    Join the club! I had exactly the same issue, initial cost was £50 to send to Prague via recorded. I had it escalated within support and they didn't budge - we have to pay it ourselves. I found TNT to be the cheapest at £27. Took about a week to come back as they send it via normal post in a jiffy bag. Grrrr!
    I spoke to Amazon after though and they've refunded me £80 back as they couldn't replace Day One stock.
  30. The SMF
    The SMF
    Nov 7, 2009
    1,792
    +154
    jees, better off picking a new one up at £50
