Davsc5 Or Dav-d150
Discussion in 'Home Cinema Buying & Building' started by Jada, Jul 14, 2004.
  1. Jada
    Jada
    Hello all
    Someone must know which one is the best? The DAVS-D150 seems to have the best quality speakers (looking at them and they weigh a ton), but the sc5 has more wattage per speaker. Also the dav-150 does not have digital home cinema. I am not worried about playing svcd's but would like to know which of these two systems is best for the larger room.
    Any help would be appreciated.
    Many thanks
    JADA
