Davs880
Discussion in 'Home Cinema Speakers' started by Scott Fawcett, Dec 14, 2002.
  1. Scott Fawcett
    Scott Fawcett
    Nov 28, 2002
    London
    I've just bought a Sony DAVS880 system and need a bit of help with the speakers.
    I had intended to use the supplied stands for the rear speakers and not for the front. I even checked that the speakers and stands could be separated. What I wrongly assumed was that there would be a connector on the speaker AND on the stand - so that either option would work. I am of course wrong.
    So, I can just stick the bare speaker wires randomly into the sockets inside the speaker - which works but doesn't feel very satisfactory. Or, preferably, I can try and find out where I can buy a suitable connector, establish which hole is + and - and wire them up properly.
    Can anyone help with this?
    Thanks.
