DAVS550 Standy Problem
Discussion in 'Home Cinema Buying & Building' started by GeordieKeith, Aug 19, 2003.
  1. GeordieKeith
    GeordieKeith
    Its a multi-region DAVS550 and I just noticed last night when I put in on Standy the light stays on for a few seconds then goes out.
    I am then unable to turn it on with the remote and sometimes even if I press the power button off and then back on it does not power off. It seems a bit hitty missy turning itself back on.
    The system is only a few months old and I was just wondering if anyone else had a similar problem.
    Any help would be appreciate
    Keith
  2. dolph
    dolph
    Dec 16, 2002
    1,191
    48
    +26
    Sounds buggered - warranty job.
    My DAVC770 works fine - haven't noticed this (basically same system)
