davs550 input volume too low
Discussion in 'Home Cinema Buying & Building' started by benjamminiriver, Jun 22, 2005.
  1. benjamminiriver
    benjamminiriver
    Hi all...
    ive got a sony davs550.
    sounds alright with drum and bass when its above 25 on the volume and in prologic 2 mode.
    ive noticed that when you have it on 2 channel it doesnt seem to use a proper crossover as the bass is very boomy,but on 5 channel it is tight.
    thats besides the point though..
    im trying to use my iriver with it, using a 3.5 to 2 rca jack, and it just isnt anywhere near as loud as playing a cd on it...
    its about as loud as putting it on 17 for the volume with a cd.
    ive tried both inputs on the back of it. and ive tried using a different device to connect, a panasonic cd player..
    whats the problema nd how can i remedy it?
    is there some way of boosting the volume via an inbetween source, I.e. a laptop? thats alli have to hand that is portable.
    seems to be louder off the cable tv box, maybe it doesnt like the 3.5mm jack
