DAVS550 best cable set up ?
Discussion in 'Home Cinema Buying & Building' started by GWM, Nov 10, 2003.
  1. GWM
    GWM
    I'm after some advice on the best cable set up,
    My tv allows SCART or Monitor only
    1) I would prefer RGB in DAV going to SCART on TV
    Would QED AV29 do the job ?
    or 2) perhaps S-Video to SCART
    Any suggestions appreciated, brand and model number also !
    Thanks G
  2. Cool-hand
    Cool-hand
    Jan 5, 2002
    2,105
    Portsmouth / Middle East
    +77
    I would just go scart to scart with a thor or qed lead. depending on your budget.
    Get a fully wired scart and enable both your tv and dav system to accept RGB. The upside of this over s-video is pin 21 auto switching. You should receive a very good picture.
    S.
  3. PaulJ
    PaulJ
    Hi There,
    Just a quick pointer. The DAVS550 does not do RGB as there is no scart.
    Only options are s-video and component.
    I personally use a monster s-video to scart cable and the picture is fine.
    Regards
    Paul :cool:
  4. MCB
    MCB
    Jan 28, 2003
    33
    Flackwell Heath, Bucks, UK
    Using Component to Component and it's spot on!!
  5. didgit
    didgit
    so what's the best quality wise, s-video to scart or component to component ? I want to make sure I'm making the right choice before splashing on expensive cables ? (sorry for "stealing" your post GWM)
  6. PaulJ
    PaulJ
    Component to component, presuming your tv can accept a component signal. If not s-video would be your next option.
    :cool:
  7. didgit
    didgit
    thanks
  8. PaulBrum
    PaulBrum
    Apr 15, 2003
    138
    Solihull
    on a further note - i have davs 550, connected to sony fq70 via s-video to scart and sky digi box connected to davs 550 by optical cable
    Whats the best set up for my Xbox so i get sound thru the Davs system?
