davs500 handset hack
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by 18j, Aug 17, 2002.
  1. 18j
    18j
    Mar 4, 2002
    108
    16
    it appears that the sony can be multiregioned through a handset that can only be used once and then must be returned to www.dvdchips.co.uk anyone used this or knows any other company with this handset.
    cheers
    wayne
  2. Guest
    there is no other company offering this
  3. 18j
    18j
    Mar 4, 2002
    108
    16
    thanks mate, I thought so as I could'nt find it anywhere else, have you tried the conpany or know anyone that has?
  4. Guest
    yes , works perfectly and fast delivery
  5. 18j
    18j
    Mar 4, 2002
    108
    16
    took your advice,ordered on tues morn the remote arrived wed multi regioned by the afternoon excellent service but you only get one go at it for your money.
    cheers.
  6. guyb
    guyb
    May 20, 2001
    657
    Leamington Spa
    +5
    Can you give me more details on the hack. What did you have to do, was it hard to do and can you break the DAV-S500 if you do it wrong. Are there any side effects etc. And how much did it cost.
    Guy
  7. Guest
    it's quite simple , follow the instructions to get your player into the Diagnostic menu then point the remote and press and hold the red key , now switch the player off and it's done. No side effects just multiregion
  8. guyb
    guyb
    May 20, 2001
    657
    Leamington Spa
    +5
    Thanks, I think that I will give it a go. I will let you know how I get on.
  9. Guest
    well ? did it work okay ?
  10. guyb
    guyb
    May 20, 2001
    657
    Leamington Spa
    +5
    Yes I have done it. It worked perfectly. I am very, very impressed. I have heard plenty of placing doing solderless/firmware upgrades for Sony machines but none that you can do in your own home. www.dvdchips.co.uk is on to a winner, they should advertise it or something so more people know about it.
  11. Guest
    they do advertise it but seems that they dont want too many customers , see this quote from the DVD and Home Cinema Hardware Forum located at www.thedvdforums.com
  12. Guest
