Davis DLS8 or Panny AE100?
Discussion in 'Projectors, Screens & Video Processors' started by joust, Mar 31, 2003.
  1. joust
    joust
    Sep 4, 2002
    944
    28
    Basildon, Essex
    +55
    Hi All,
    Have the option of the above 2 projectors - which one will be better? Will be used mainly for DVD's (will feed from a HCPC, probably with Radeon 9000 graphics), with the occasional Sky/PS2/GC use (through a dscaler). This will be projected onto either a 5/6' 4:3 or 16:9 screen.
    Thanks in advance.
    Joust
  2. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,153
    UK.
    +2,671
    I was using an HTPC with my DLS8 for 3 years and got impressive results.
    The advantage of the Davis over the Panny is black level, screendoor and reliability.
    The panny is of course widescreen, but the difference is minimal.
    I take it you don't suffer from the rainbow effect then?
    I saw an Infocus X1, and the image looked very similar to my DLS8 and htpc combo, except the X1 had less halo.
    hth
    Gary.
  3. Port
    Port
    I saw both these demo-ed on the same screen last year. I greatly preferred the Davis. Far smoother, bigger but brighter picture, though colour not as strong. As usual, if you are affected by rainbows, this would be a danger. Davis is now quite old, and I would hope that any more modern DLP would be even better.
