Davis CinemaOne
Discussion in 'Projectors, Screens & Video Processors' started by DRC, Jan 30, 2002.
  1. DRC
    DRC
    I have a chance of getting a Davis CinemaOne for around 1700. ( local shop in sweden)
    What do people think of the machine.:confused:
  2. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    I thought they went out of business. From my recolections it was a reasonalbe DLP projector but suffered from the rainbow effect big time.
  3. tryingtimes
    tryingtimes
    Feb 15, 2001
    4,094
    +548
    Colours are probably it's weakest point and it's anamorphic mode shouldn't be used.
    It wasn't terrible, though
    £1700 for brand new guaranteed probably isn't bad. But most would find the other (newer) projectors in the £1800-2300 bracket easier to live with.
    Second hand - I wouldn't consider it myself.
    Hope that helps.
    Regards
    Alex
  4. DRC
    DRC
    Thanks for the info
    You have confirmed what I thought.
    So now it will be a wait and see between the new panasonic and the monroe.
  5. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    There's a shop in Sweeden thanking us very much.
    "Put it back on the shelf boys":D
  6. Mark Grant
    Mark Grant
    Oct 27, 2000
    1,357
    63
    East Yorkshire, England
    +171
    Hello DRC,
    The Davis SVGA DLP projectors are great as long as you use a HTPC / HCPC.
    The internal scaler is poor, this is why people complain of poor colours and rainbow.
    Use a HTPC and you will be happy, and should not see rainbows because of the increased 72Hz or 75 Hz refesh rates.
    You might as well buy the DLS8 if you can find one any cheaper, that is a great projector when used with a HTPC.
    Might be worth asking the same question on the other forum ;)
    http://www.avsforum.com/avs-vb/
    You will need an EVC to VGA adapter cable to get the best from a Davis projector.
    If you need an EVC to VGA , mail me, I might just be able to find one ;)
    Good luck,
    Mark.
