Dave's Garage Conversion
Davidjake07
Established Member
Hi All ,
Been lurking on here now for a few years and got some great info and idea's on all things relating to home cinema so i thought it was time i shared my build :)
Background info:
Been into home cinema now for years now and had a set up in one of my bedrooms for a few years but always had the same problem i was really restricted to when i could use my room due to the sound transfer to the rest of the whole house , you could here it everywhere and as soon as Mrs DavidJake went to bed then forget it !!!!!
So around FEB 2015 i decided that a garage conversion was in order and duly got some builders around to quote on the job , around the same time i made some general enquiries to the council about building regs and the sort , only to be told that i needed planning permission to convert and make my garage into living space, this was due to parking restrictions they count a garage as a parking space even though my garage has never seen a car in its life and would doubt could even get one in there , so after months of wrangling with the council permission was granted and work finally started August 2015
Davidjake07
Established Member
So here is a ground floor plan with garage before conversion
Above is a plan for proposed work
Garage approx 5.2m x 2.5m and is to be split into two sections one being the main home cinema the other to be a small utility room which will house my equipment rack with all my stuff and a washer and freezer
so with that in place i will be looking at :-
Cinema room 3.7m x 2.3 finished
Utility Room 1.5m x 2.3 approx
Not a great deal of space to work with i know but you have to work with what available space you have
The first thing i had done was get the sparky in to move consumer unit from its original location my proposed cinema room into what would be the new utility room
Didn't take loads of photos of build but what i have will post on here
ENJOY !!!
Davidjake07
Established Member
new consumer unit fitted and moved next to boiler stud wall gone up 125mm thick to make room for inwall speakers
looking from utility into cinema room with metal frame stud wall also up and window fitted
walls to be filled with 100mm rock wool insulation and double plasterboard with sound block
false ceiling put in with resilient bars to be fitted and filled with 100mm rock wool and also double sound bloc plasterboard , also pic shows window fitted and door opening from hallway , glass was specced to be a double glazed unit with 4mm and 6mm panes for sound insulation the idea is the different thickness of glass cancels out the noise and helps with sound insulation
Davidjake07
Established Member
There was a really awkward supporting steel beam that ran the full length of the garage this would ultimately dictate the width of the room as nothing could be done about this !!
Davidjake07
Established Member
View from cinema room showing stud wall and locations of inwall speakers , the floor height was kept lower than the rest of the house so there is a step down into the cinema room , this was done to keep ceiling height for the atoms speakers
After room shell finished a plinth would be built housing lighting and atoms speakers , after all the effort of making the room as soundproof as possible the last thing i wanted to do was start cutting holes in ceiling
I have chosen 6 x philips Hue gu10 spot lights for lighting as these can be controlled by my iPad with different scenes with roomie remote , for example when when a movie is paused it can send a signal for my lights to turn on or select a certain scene , really clever and simple to set up
Davidjake07
Established Member
Anyway onto the good stuff since starting planning my room i knew from the beginning that i wanted the speakers to go in the correct location behind the screen and it would be a 5.1.2 Atmos setup due to room size so with that in mind went over to Normanton and spoke to Allan @ Ideal Av who duly ordered me a Seymour Centre Stage XD screen 2:35:1 aspect 2 meters wide and some MK Sound IW150's + IW85's for atoms duties ( although these would not be used yet until i have the funds for a new atoms processor)
Existing equipment that is to be used :-
TOSHIBA HD DVD (now gone)
Acer Revo PC Running OPENELEC KODI
Panasonic Blu Ray Player
QNAP NAS with 4 x 3TB WD Red Drives
Onkyo 5509 Processor
Bryston 9BSST Amplifier
JVC x3 Projector
Darbee Video Processor
MK sound SS150 Surround Speakers
MK sound MX350 Subwoofer
IPAD with Roomie Remote
Also orded a new rack to house all this stuff
back of rack with everything wired up , equipment will be controlled by iPad over IP with Roomie Remote
Front of rack in new utility room
Davidjake07
Established Member
Rubber seal fitted into door frame to help with sound proofing , when door is closed you can hear and feel a rush of air as door is sealed tight when closed , although the door is always going to be the weak point when trying to sound proof a room
new door fitted FD30 finished in oak this thing weighs in excess of 50KG and helps a lot with sound transfer along with rubber seals fitted all around frame
Davidjake07
Established Member
Speakers fitted into wall ready for screen to go up , had extra plug point fitted and ran another sub cable into corner of room for an extra sub just in case :)
Davidjake07
Established Member
Finished room Pics !!!
Hope You enjoy them its been a hard long slog but i am really happy with finished room and to my ears sounds great , room always looks smaller in pics than it actually is although not massive its amazing what can be done with even a relatively small space and feels a good size when your sat down ready to watch a film , will be happy to answer any questions regarding build and set up
cheers
Davidjake07
Established Member
Hue Lighting looks GREAT loads of Color Combo's
Solid aluminium Custom Made Blind from ORDERBLINDS.CO.UK for TOTAL Blackout
status42
Established Member
Very nice well done
Davidjake07
Established Member
Cheers Thanks for comments !!!
Maxx reload
Established Member
Looks very good, and certainly helping me with my thoughts and plans.
really like the solid blind too.
CableGuy
Love it. Really tidy setup. I always have speaker envy with the MKs. :)
SparkerB
Established Member
Nice one. I am sitting in a room about the same size. Your project has revived my hopes of converting it. Could you get two sofas in there, one on a raised floor?
Davidjake07
Established Member
Cheers for comments guys !!
The blind is custom made you have to supply all measurements top middle and bottom and it comes in three sections top part contains blind and two side rails (every thing is included to fit) with tracks for the blind to run up and down , its manual operation you tilt the bottom rail away from you which releases mechanism and can be moved up and down as soon as you let go it locks blind in that position , it really is a nice piece of engineering and is really well made , feels solid and has a rubber seal on bottom to stop light getting in
Davidjake07
Established Member
i think you would struggle to get another row in here TBH the seating distance is about 3m from screen which is just about right , i think if you where to put in another row you would prob be about 1 - 1.5m from screen far too close
Davidjake07
Established Member
Here u go !!
Will Try and Get some more photo's up later on
Davidjake07
Established Member
Pic of Roomie Remote on iPad with two way control for all my components including lighting and heating a really nice piece of software easy to set up and works well
Davidjake07
Established Member
Another Pic of Blind Showing Side Rails
Kalamos Sofa From DFS comfortable seating for Three :)
LG G3 MLA OLED Evo Best Picture Settings - works for ALL 2023 LG OLEDs
Back
