Davek0974
Ok, after much reading and asking questions on this excellent forum, I think it's about time to get my build thread going.
It's early days yet, only started on 15/02/2013 but already have the 2.9m x 3.8m former bedroom cleared, stripped, filled, sanded and prepped for work.
Tonight I levelled and mounted the support battens for the screen, this will be a 2.1m wide 16:9 format fixed screen from MDF sheet. This was then primed on the back and mounted, the front will be coated with grey primer then two coats of "Pourascreen" paint, a grey finish with a gain of 0.85.
Wallpaper will be a black leather effect from B&Q, ceiling is going dark matt grey and I'm fitting a halo with led lighting and led downlighting around the perimeter.
Pictures to follow.
Pictures to follow.
