Dave vs AVR300
Discussion in 'Arcam Owners' Forum' started by vistisen, Dec 8, 2004.
  1. vistisen
    vistisen
    Jul 10, 2004
    83
    Silkeborg
    +3
    I am the happy owner of an Bi-amped FMJA22 and CD23T based system. But I want to have suround sound when seeing films on DVD. I am not interested in SACD,DVD-A or 7.1 channels.
    Simple 5.1 Dolby and DTS is what I want. So for just this one need, how difference is there in terms of Sound quality between buying A DAVE module to my A22 and buying an AVR300?
  2. barnythebear
    barnythebear
    Jul 6, 2004
    152
    leicestershire
    More processing modes on the AV300. You could keep the A22 for your main stereo and run it in processor mode when using the AV300 for DVD.
  3. vistisen
    vistisen
    Jul 10, 2004
    83
    Silkeborg
    +3
    But I don't want more modes, just 5.1. Is there a difference there?
  4. steeled
    steeled
    Apr 23, 2002
    484
    28
    Maidenhead
    +53
    Hi Vistisen
    I don't think the DAVE module is available anymore from Arcam. You would have to find a second hand module. (These are factory fitted not just plug in.)
    The DAVE module does not contain extra amplification. You would need three channels of amplification for the rears and centre. This would normally be provided by a P25/3 which has three channels.
    The DAVE is a good product but is very limited in it's bass management. You can not change the cross-over frequency or anything like that.
    Hope that helps.
    Dave Steele (Alpha 10/DAVE Alpha 10P3 owner)
  5. bluesfan
    bluesfan
    Feb 10, 2004
    303
    16
    Yorkshire
    DAVE boards are not av anyone as confirmed by Arcam. They don't even have boards for repairs! The A22 and A32 are really aimed at sacd/dvd audio not tv surround or dvd. Separate processors is a daft approach and an integrated solution is a much better approach. Having said the surround sound for music is infinitely superior to an av receiver.
  6. barnythebear
    barnythebear
    Jul 6, 2004
    152
    leicestershire
    You can make the 300 do more with 5.1 material. You can also have a 5.1 effect from 2 channel source material. It can be set to Pro logic II with either a movie or music mode also DTS to work in the same way. Should you decide to add more channels then they are sitting there waiting. I've had new biamped speakers for my front three channel and kept my old Bose AM15 to run as the four rears. Seems to work OK. As they say get a demo and see what you think.
