dav550 svcd problems
Discussion in 'Blu-ray & DVD Players & Recorders' started by Ashy, Jun 10, 2003.
  1. Ashy
    Ashy
    Jan 3, 2003
    377
    +14
    having the odd problem when playing back some svcds. what happens is that it stutters and the sound stops and sometimes it just freezes.
    this only happens on the odd one or two but when ive checked the svcd on my pc using power dvd it plays fine so the actual svcd cant be at fault.
    any ideas what could be causing the problem and if so how to fix it?
    thanks in advance, most kind :)
    Ash
  2. zorg2000k
    zorg2000k
    Jun 5, 2003
    367
    +15
    I take it you mean Sony DAV 550 ?
    If so its not meant to play SVCD's, I have a DAv 500 and im in the same boat. Although you can trick the player to play them by changing the header and re-burning the disc. More info on that can be found on www.vcdhelp.com.
    L8tr
    Zorg
  3. Ashy
    Ashy
    Jan 3, 2003
    377
    +14
    it plays svcd all the time mate as long as you dont have it set to progressive scan, i found the problem i had was caused by burning to cd to fast. got told to burn at no more than 8x
