DAV-SC5 or6 Sound controls Vs DV99
Discussion in 'Home Cinema Buying & Building' started by jaymac, Jan 30, 2004.
  1. jaymac
    jaymac
    Jan 15, 2003
    1,725
    63
    North Somerset
    +138
    I'm looking at these or the pioneer dv99 I have the manual for the 99 and the sound adjustments/setup seem pretty comprehensive. What I need to know is do the sonys allow each speaker to be adjusted indvidually not just in pairs. Has it got treble/bass adjustment or just stepped settings on the sub. I asked at comet but the guy hadn't even heard of sacd or dvd audio say no more. all comments will be appreciated
  2. doodar
    doodar
    Jan 19, 2004
    london
    jaymac
    yes, you can set up the speakers independently
    no, you have no extra control over the treble/bass, but you have 3 settings for the sub which is pretty effective
    i would recommend the sc5 - it's awesome!!
  3. doodar
    doodar
    Jan 19, 2004
    london
    btw
    i got my multi region sc5 online from rgbdirect.co.uk for £329 delivered!
  4. jaymac
    jaymac
    Jan 15, 2003
    1,725
    63
    North Somerset
    +138
    Thanks doodar thats what I needed to know but might go for the sc 6
  5. marcusf
    marcusf
  6. devastator
    devastator
    May 15, 2002
    1,511
    48
    +49
    I also have the SC5 ... very good, sound easily fills out my 14x16 room :)
  7. WilliamSmith
    WilliamSmith
    Dear guys,
    The SC6 has a better front channels with a balanced dome tweeter and an additional 7cm woofer for a better sound.
    If the budget permit, the SC6 with benefit you with a better sounds from the front channels.
    Regards,
    Will.
