DAV-DZ260 sub-woofer
Discussion in 'Home Cinema Buying & Building' started by Skiffmeister, Feb 3, 2009.
  1. Skiffmeister
    Skiffmeister
    Jan 16, 2009
    7
    Bonnie Scotland
    Is there any problem placing the sub-woofer on it's side?
    It would then fit neatly onto a glass shelf beneath the TV
  2. Badger0-0
    Badger0-0
    May 30, 2005
    20,601
    Spaghetti Junction (really)
    +1,923
    As long as you're not blocking any port, it won't be a problem :smashin:
  3. luke90
    luke90
    Aug 16, 2008
    466
    28
    Chesterfield
    +40
    Its not a problem. Just make sure the glass shelf does not vibrate/rattle.
