Daughters uni laptop doesnt find my wireless network
gerbilly
Anyone have a clue how to do this my daughter has come home with a laptop from Uni, to help with some dissertation project. It is an old Toshiba Tecra A2 with windows xp running on it. I clicked on available wireless networks and it finds about 4 or 5 in the area but not ours. I use a virgin media modem (50mg one) connected to an airport extreme (2 yrs old) and it doesnt find our 5ghz network or the lower one.
CamFire
Did you set the AEBS to "hide" the 2.4GHz network's SSID? Or, could it be that the Toshiba is capable of using channels 1 to 11 (of 2.4GHz) and your AEBS is set automatic or channel 12 or 13?
EDIT: and watch out for that N-only operation at 2.4GHz; this needs to go back to b/g/n settings.
gerbilly
im an idiot when it comes to wireless networks dont know what you mean with this, could you put in idiot terms for me.:blush:
CamFire
Will the following two snap-shots, taken from AirportUtility, help?
The "closed network" refers to a SSID-hidden system, while you can figure out the "13" for the 2.4GHz.
gerbilly
In your second screen mine shows
The name of my wireless network
allow this network to be extended is not ticked
radio mode shows as 802.11a/n - 802.11b/g
channel selection Manual 44 (5ghz) 12 (2.4ghz)
wireless security wpa/wpa2 personal
wireless password and then verify password after this.
as for the first screen shot mine is the same as yours.
CamFire
Change the 2.4GHz setting to channel 6 and see what happens to the Toshiba laptop.
Once confirmed that the Toshibas has a USA-type of wifi card (which supports channels 1 to 11) only, download iStumbler onto the Mac, sniff the neighbourhood for a un-used channel and configure the AEBS to that.
gerbilly
Done that mate and it works:thumbsup:
However the damn laptop doesnt connect to internet despite being attached to network with an excellent signal:confused::confused:
CamFire
I'll admit that where there's anything to do with networking on windoze machines, I'll pop down to the IT department. ;)
Failing that, down to PC World for a £70 discount for a new MacBook :smashin:
spudtator
If it's a Uni laptop it may well be configured to access the internet through a proxy server.
Can't remember exactly and I don't own a PC, but check in Internet Explorer options or the Internet control panel. There should be a 'connection' option somewhere. If it has 'use a proxy server' selected, turn that off.
CamFire
I do recall a Network "assistant" of some sort accessible via the Control Panel. See if it is as friendly as MacOS' approach.
gerbilly
it isn't:D
I will try the proxy settings thing once my daughter has got out of her bed:D
bloody students:D
spudtator
Fat chance :devil:
From within Internet Explorer, it's the 'tools'>'options' menu. Connection tab, then LAN Settings. (Had to look that up).
Same thing is in Control Panels somewhere as well.
gerbilly
It isn't selected, still not working?:mad:
spudtator
There's a load of things this could be. I can try and help out, but it might be better if a Mod moved this to the Windows board. You'll probably get a lot more help there.
Couple of things to try though.
Click on Start and 'run'. In there type cmd and hit enter.
In the black box that appears type (without the quotes) 'ping www.google.com'
and hit enter. Does it get a reply?
If it does, that tells you that your PC can connect to the internet and it would suggest the problem lies with Internet Explorer. In which case you can reset IE from within the 'tool'>'options' menu.
Are there any other browsers on the PC? e.g. Firefox
As you know, you've got as far as connecting to the router, it's just getting that one step further.
thedude
Update the drivers had the same issue myself.
CamFire
OK, am in office now behind a windoze machine...
Try:
- Start > Control Panel
- Network and Internet Connections
- Network Connections
- right-click the "correct" one (as there may be a few) and select "repair"
Disclaimer: I know none of the above if the laptop explodes...:D
