date
Discussion in 'Photography Forums' started by cazxx1, Sep 8, 2005.
  1. cazxx1
    cazxx1
    hi iv took a lovely pictr of my sons trouble is iv got the date in the corner of it any ideas how to get rid of it thanks
  2. seany
    seany
    May 1, 2003
    2,997
    61
    Manchester city
    Well we need to know what camera you're using. If it's already imbedded in the photo. Then you're going to have to use softwear to remove it. There should be an option in the cameras menue to stop it doing that in the future
  3. mr jones
    mr jones
    Oct 23, 2004
    1,041
    41
    (S)cumbria, UK
    +21
    im sure someone could clone it out in photoshop, or crop the image to remove it if you emailed the image to them
    having the date applied to the image is great, but it does tend to wreck the image, you should be able to remove it somewhere in the cameras settings. the date is still retained in the exif data from the image so not having it on the image isnt a problem.
