Quantcast
Datawrite
Z
zach54
Has anyone else had trouble with Datawrite Red ( V3 ) on their machines? I have a Panasonic E60 and it just wont recognise any Discs!! I was gutted about that so I went and tried them in my DVD-RW and they wouldnt work in there either!!!! The Horror...the horror..........
kenfowler3966
I have used datarite reds, with no problem. It has been said though that you must use and finalise them in one session before removing from the recorder as otherwise they can't always be read when re-inserted.
Z
zach54
Thanks for the reply Ken.Out of a spindle of 25,I have managed to use 14.The really funny thing is that Ive used them on my Panasonic DVD player and yet once they have been finalised the Panasonic struggles to read them!!:confused: But the other DVD players seem to play them ok.
Im glad you seem to being having a lot of success with them
