Datasat LS10
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by abone, Jan 30, 2014.
  1. abone
    abone
    Sep 25, 2007
    399
    46
    +159
    Here is some info on the new cheaper processor from Datasat
    The Datasat LS10 is the first home cinema processor to deliver high end audio features at a price point for a wide range of home cinemas and media rooms. The Datasat LS10 with Auro-3D® makes full immersive sound in 3D available to those installations for the first time.
    Bringing immersive sound to the home
    Auro 3D® adds height and top layers to standard digital surround sound. This provides a much more natural listening experience in which the texture and directional nature of the sound can be fully appreciated. The Datasat LS10 with Auro-3D® allows playback of native Auro-3D content as well as upmixing 2.0, 5.1 or 7.1 soundtracks into the Auro-3D format. It is ideal for home cinema installations where price and performance are important considerations.
    Stylish and powerful
    Featuring precise control of each of its 15 channels – with 10 bands of parametric equalisation per channel - and superior bass management, the Datasat LS10 ensures high quality sound that is rich, textured and realistic. In addition to Auro-3D®, this processor provides native support for the latest sound formats including Dolby TrueHD, DTS-HD Master Audio and DTS Neo:X. Its range of remote control options – including VNC control through iOS and Android devices – places this audio power at the user's fingertips.
    A COMPANY
    Digital Audio Decoders
    Auro
    • Auro-3D® Decoding Engine • Auro-3D® Upmix Engine
    Dolby
    • Dolby® Digital Plus
    • Dolby® Pro Logic® IIz • Dolby® TrueHD
    DTS
    • DTS-HD Master AudioTM • DTS Neo:XTM
    Signal Inputs
    HDMI Audio & Video Inputs:
    • HDMI V1.4a with video pass- through (8 in/2 out)
    Digital Audio Inputs:
    • TOSLINK – 2
    • S/PDIF – 2
    • USB 2.0 – 1
    Analog Audio Inputs:
    • Channels: 2 stereo single-ended input pairs
    • Connectors: 4 RCA jacks
    • Impedance: 10k ohms
    • Sensitivity Adjustable: -16dBv to -4dBv
    Signal Outputs
    Analog Audio Outputs:
    • Channels: 15
    • Balanced (can be connected unbalanced or single-ended
    • Connectors: 15 XLR
    • Level: 300mV with Fader at 7, +26dBu max (balanced)
    Audio EQ
    Parametric
    • 10-band parametric EQ
    • Adjustable from 20Hz to 20kHz, gain +/-6dB i•0.1dB steps
    • Q range from 0.7 to 5
    Bass Management
    • Full or adjustable high pass settings for screen and surround speakers
    • Adjustable low pass filter for sub woofers
    • Support for 0 to 2 subwoofers
    Audio Delays
    Individual Channel Delays:
    • 0-100ms
    Global Delay:
    • 0-100ms
    Note: Total delay per channel not to exceed 100ms
    Control
    • RS232 DB9
    • 10/100Mbps Ethernet
    • VNC control including by iOS and Android devices
    • Crestron Integrated Device
    • IR Remote
    Power Requirements
    • 100-240 VAC, 50-60Hz, auto- switching
    • Power consumption TBA
    Regulatory Compliance
    • UL CB Scheme
    • FCC Part 15, subpart B Class A • CE
    • RoHS compliant
    E&OE
    All product specifications subject to change without notice. All trademarks are properties of their respective owners.
  2. Mr_Orange
    Mr_Orange
    Mar 23, 2008
    3,043
    Brisbane
    +289
    "cheeper"? really? You don't mean "cheaper"? I would have thought that "less expensive" is more the correct description. The words 'cheap' and 'Datasat' should never exist in the same sentance!
  3. Graham N
    Graham N
    Feb 24, 2004
    1,653
    Cornwall
    +307
    If you are picking up on cheeper vs cheaper sentance is actually sentence ;-)
  4. TomScrut
    TomScrut
    Jan 11, 2012
    2,669
    Scarborough, UK
    +438
    I always thought cheaper meant less expensive?!
  5. PuppetMaster120
    PuppetMaster120
    Oct 13, 2010
    180
    +17
    Whats difference between this Datasat system and an AV system that has Audyessy built-in sorry for the lame question but am pretty new with the whole Datasat name?
  6. TomScrut
    TomScrut
    Jan 11, 2012
    2,669
    Scarborough, UK
    +438
    What exactly do you mean?
  7. PuppetMaster120
    PuppetMaster120
    Oct 13, 2010
    180
    +17
    Like how does it compare, to an ordinary AV Receiver.
    Thanks in advance
  8. TomScrut
    TomScrut
    Jan 11, 2012
    2,669
    Scarborough, UK
    +438
    I thought you might want to be more specific than that as there is probably a lot of difference especially as it depends on what you regard as an ordinary av receiver. Essentially it is as far as I am aware the best or one of the best processors money can buy in terms of both features and sound quality. If you want to know about features look at a featur and list
  9. sounddog
    sounddog
    Dec 11, 2002
    3,446
    107
    Leicestershire, UK
    +480
    No, it's like Aston Martin make expensive cars and less expensive cars.
    On the other hand Vauxhall and Citroen make expensive cars and cheaper cars!
  10. TomScrut
    TomScrut
    Jan 11, 2012
    2,669
    Scarborough, UK
    +438
    But a V8 Vantage is still cheaper than a DBS, not cheap but cheaper
  11. sounddog
    sounddog
    Dec 11, 2002
    3,446
    107
    Leicestershire, UK
    +480
    I think you are missing the subtle difference between less expensive and cheap / cheaper...
    Something which is less expensive costs less money but is still built with the same attention to detail.
    Something which is cheap(er) costs less money, but the money saved is because it is less well built, or misses important functionality.
    Eloise
  12. TomScrut
    TomScrut
    Jan 11, 2012
    2,669
    Scarborough, UK
    +438
    Sorry I see what you mean. I was under the impression that cheaper was purely meant in terms of comparison of price and not other factors such as build quality etc
  13. sounddog
    sounddog
    Dec 11, 2002
    3,446
    107
    Leicestershire, UK
    +480
    Its subtle but yes, often cheaper / less expensive is used as an assessment of quality as well as purely price. Often "it's cheap" would be a put down comment.
  14. TomScrut
    TomScrut
    Jan 11, 2012
    2,669
    Scarborough, UK
    +438
    Yeah I would use cheap in that respect but I just thought it was derived from lower price and therefore cheaper meant less expensive. I have looked at a definition online and I agree you are right
  15. sounddog
    sounddog
    Dec 11, 2002
    3,446
    107
    Leicestershire, UK
    +480
    Datasat are (iirc) the new name for the company behind DTS sound.
    The Datasat RS20i was built on similar platform to the commercial units used in your local multi-plex (the ones with good sound not the mediocre ones :) ). The new LS10 is designed to bring similar technology to a slightly lower price point. While I have not seen all the details, it would appear to do this by replacing the modular construction of the RS20i with a fixed configuration which will suit most users. How they compare in quality is not yet know.
    I would suspect (but don't know) this will be one of the best processors available in a pure home cinema environment (when coupled with suitable partnering equipment).
    Eloise
  16. abone
    abone
    Sep 25, 2007
    399
    46
    +159
    Correct, it's not as flexible as the RS20, the LS10 has fixed input and output channel mapping and manual EO but it has the same DSP engine and DAC's so I'm sure it will sound awesome. Roughly 1 more week and we should know for sure.
  17. rigman
    rigman
    Dec 14, 2000
    2,990
    83
    East Yorkshire
    +132
    It is a real pity it does not have Dirac or even a dumbed down version.
  18. PuppetMaster120
    PuppetMaster120
    Oct 13, 2010
    180
    +17
    Thank you for the description of what Datasat is, i never knew that DTS was created by them, i hope to see these systems on the market i wonder how much they will cost since you said that they pure audio. I bet they are going to sound way better than the medicore systems.
    Thanks again Eloise
  19. lucmor444
    lucmor444
    Jan 16, 2006
    324
    28
    Melbourne
    +61
    Hi Abone - any update on when you may be getting a unit?
  20. abone
    abone
    Sep 25, 2007
    399
    46
    +159
    Still no news, Datasat said the last week in May for official release of LS10 and we should have Auro the week before ???????
  21. lucmor444
    lucmor444
    Jan 16, 2006
    324
    28
    Melbourne
    +61
    Thx Andy - hopefully an update will be provided soon. I notice that Storm Audio are now listing the Auriga on their website.
  22. sammy the squid
    sammy the squid
    Jul 5, 2009
    9,012
    Lancs
    +3,630
    The Auriga was launched a few weeks ago. I think it was mentioned over on AVS forum that the LS10 was now due for release in June.
  23. abone
    abone
    Sep 25, 2007
    399
    46
    +159
    At last the LS10 is shipping, but without Auro for the moment. :)
  24. sammy the squid
    sammy the squid
    Jul 5, 2009
    9,012
    Lancs
    +3,630
    That's unfortunate news for anyone investing in that processor and hoping for Auro on launch. Let's hope Datasat get things in order and deliver Auro as per their earlier press releases, sooner rather than later:thumbsup:
  25. abone
    abone
    Sep 25, 2007
    399
    46
    +159
    Yes, not sure why it's taking so long there must be an issue of some sort.
  26. Mr_Sukebe
    Mr_Sukebe
    Mar 10, 2004
    2,397
    London
    +214
    Does the opening post need amending to say "the Dataset LS10 should have auro processing...sometime soon...."
  27. lucmor444
    lucmor444
    Jan 16, 2006
    324
    28
    Melbourne
    +61
    It has been indicated over on avsforums that Datasat has found a bug with Auro on their platform that they are working on. I would consider the source of that information as reliable.
  28. Wookii
    Wookii
    Mar 19, 2007
    1,133
    Nottingham
    +236
    They certainly need to pull their finger out
    Where abouts on AVS?
  29. sammy the squid
    sammy the squid
    Jul 5, 2009
    9,012
    Lancs
    +3,630
  30. Wookii
    Wookii
    Mar 19, 2007
    1,133
    Nottingham
    +236
    Cheers Asif - I'm subscribed to that thread as well - I never seem to get all the 'new post' emails from AVS!
